Hi folks,
Need some help here. Has anybody disassembled a Keter deck box, Brushwood model?
Clicks together easily but with zero instructions in the box, I need to take an end off and it is proving very difficult.
Welcome to the Bunnings Workshop community @Danno72. It's fabulous to have you join us, and many thanks for your question.
There are quite a few Keter deck boxes, and the instructions for them can be found on their website. If you click on your version, you'll then find the assembly instructions under the product features label.
I would presume that you're finding it difficult to remove the end piece because these boxes utilise click together connectors. I do not doubt that once they are connected, it would be tricky to undo the panels. If you start at one corner and work your way across with a thin flat-head screwdriver, you might be able to release the connectors one at a time.
What was the reasoning behind needing to remove the end? If you have run into issues during the assembly process, I trust our team in-store would be more than happy to assist.
Please let me know if you need further assistance or have questions
Use a pry bar and push it up in the space between the two sections where the connector is and press into the connector while lifting up, once the first connector is free move the pry bar down the line without removing it and continue the process for the other two connectors. Worked for me
Hi @Kellyc45678,
Greetings and welcome to the Bunnings Workshop community. We're delighted to have you with us.
It seems like a prybar would certainly be the way to go.
Thank you for sharing your experience.
