Simple question.
Do the Goliath drawer glides enable drawers to be easily disconnected without unscrewing them?
My daughter is replacing some and needs to take drawers all the way out.
thanks
Welcome to the Bunnings Workshop community @apamakes. It's wonderful that you've joined us and many thanks for your question.
Could you please clarify if your daughter has Goliath drawers sliders and you wish to know how to remove them, or are you looking to install them but only if they are easily removable? In either case, they are not what I would call easy to remove.
The only Goliath drawer glides that can be removed once installed are the standard, push to open, and soft close. However, they are not something that you would want to remove often as the release mechanism is tricky to operate. The heavy-duty range is difficult to remove, and they could be damaged in the process.
It sounds like you might be after something more similar to the older style drawer sliders. These are exceptionally easy to remove. You need to fully extend the drawer, lift the front and remove. The drawer goes back into place just as easily.
Thanks Mitchell,
I was thinking that was the case. She’ll need to remove often so we’ll use the older style track and wheel.
thanks again
Papa
