Two new decks create zones for both relaxing and entertaining in this remarkable backyard renovation featuring a matching daybed and planter box.
The project
I've been wanting to renovate my backyard patio since I purchased this property early last year. The outdoor area was looking tired and letting down the overall look and feel of the space.
Finally got the time this winter to tackle my first outdoor D.I.Y. project. I was able to achieve the look I was after, so I'm happy with the results. Our outdoor space is a lot more inviting now.
The majority, if not all, of the tools and hardware used for this project were sourced from Bunnings. At a high level, these were the completed jobs:
- Built two treated Pine decks – 4300 x 4100mm and 4200 x 4200mm.
- Built a daybed 2400 x 800 x 450mm.
- Built a planter box 3600 x 600 x 800mm. I used H4 treated timber sleepers and posts for the planter boxes frame. I also used some treated pine decking boards over the sleepers for the dressed look. These were the same boards I used for decking.
- Planted Bangalow Palms, hoping they will grow fast and screen the neighbour's windows. I also plan to fit outdoor roller blinds to the pergola for additional privacy.
- Installed Holman deck lights. They are D.I.Y. friendly and easy to install. You will need to install the Holman controller/transformer to draw power to the LED lights. It supports up to 60watts and each of these LEDs only require around 0.6 watts, so you can connect plenty of lights. I also installed Holman spotlights to highlight the palms and trees. If you decide to use these lights, go for the Bluetooth-enabled controller. I control switching the lights on and dimming the lights all from my phone.
- Spray painted the fence using Dulux RapidFinish paint.
- Built a wall feature using garden screening and a LED strip.
Before and after
How to renovate a backyard patio
Chiren_J captured a timelapse video of this project so you can see how to tackle a D.I.Y. patio renovation.
More inspiration for your outdoor areas
Find more wonderful ideas for renovating your outdoor areas in our Top 10 most popular outdoor projects and Top 10 most popular deck projects.
