Here I have made thei mdf barn door with a cross feature.
All materials were purchased from Bunnings
MDF
Barn Door 3m slide rail
I will add before and after photos 🙂
Hello @LePallet
Thank you for posting that beautiful barn door. Did you cut the design out of the panel or did you do it piece by piece? Either way it looks amazing.
Thanks @EricL
I used a sheet of mdf and then cut every piece
@LePallet
How thick is it? Normal door thickness?
@pstq the door is 40mm thick
Thanks
@LePallet Wow that is absolutely stunning. Such a great idea to have it black - it suits the room perfectly. Amazing job!!
So it's 3 layers of MDF? Glued together?
Hello @pstq
Thank you for joining the discussion. Let me tag @LePallet so that he is made aware of your question. Are you planning to build your own barn door? I'm sure our members would be keen to see your project.
If we can assist you with any of your projects, please let us know.
Hi, Can you please provide a quote for this door? are you available to build and install two such doors in my home? colour preference Antico oak.
Welcome to the Bunnings Workshop community @saima01. It's great to have you join us and many thanks for your question on custom made doors.
This is a project made by the talented @LePallet. He's constructed it himself from MDF board. If you'd like to give this a go yourself, I'm sure our helpful members will have plenty of advice for you.
If you'd like to have a custom barn door made, you can check out what's available through our supplier Hume doors. Once you decide on the style you're after, we can go ahead and place an order for you.
We do offer door installation and you can organise this with our Special orders team over the phone as you're placing your order.
Hi @LePallet ,This looks amazing. I'm keen to try something similar for the walk in robe door in our bedroom. What size MDF did you use and did it produce a sturdy, thick door?
Welcome to the Bunnings Workshop community @TomG. It's brilliant that you've joined us, and many thanks for jumping into the conversation.
Hopefully, @LePallet can get back to us with some details on what thickness MDF sheets were used. I suspect that 18mm MDF was used as it's the thickest available off the shelf. Or, potentially, a combination of other sizes. Two boards would be needed to achieve 36mm, and one of those sheets cut out to suit the pattern. Another 3mm sheet could be added to get you close to the 40mm mark. It looks like @LePallet has cut the pieces for the pattern out individually. I wonder if you could mark out your pattern on the sheet and cut just the voids out with a jigsaw? That way, you wouldn't have to work out all the different angles and use filler at the joins.
A 40mm thick door constructed from MDF would be extremely sturdy.
I'm looking forward to hearing more about your project, and hopefully, @LePallet will get back to us soon.
Excellent door! Would you happen to remember the measurements of the outside panels and the diagonal panels on the door? The balance between them looks amazing.
Hi @Tamaraskie,
Let me mention @LePallet to see if he can fill us in on those details. I could only hazard a guess, but since the rail is 3m long, the door width could be around 1.2m wide as it appears slightly less than half the length of the rail.
