Hi all, I am seeking answers to 3 questions i have in regards to building a detached Pergola.
The size of the detached pergola will be 5m x 4m
Q1. Based off the pergola size (5m x 4m) is it better to attach the beams (240 x 45mm) to a 4 x post structure or with 6 posts?
Q2. Research has shown two ways to set up the beam structure as being either:
●1 x beam (per single side) cut into the posts as a rebate at either end ; OR ●to have 2 beams, one placed at the front and one at the back of the post. Which is better method support?
Both would be use a coach bolt and nut to fix.
Q3. With regards to knee braces would you fix each direction off the post to better secure (meaning post to beam and post to rafter) or only along the post to the beam?
These are the 3 questions stumping me before moving forward. Support in answering is greatly appreciated.
