Difficulty: Beginner
In-ground worm farms turn food waste into rich organic fertiliser that your garden will love. They’re low-maintenance, blend into your garden and you can use pots you already own.
Getting started is easy. You can build and install your first worm farm in around one hour anywhere in the garden or even in a raised garden bed.
Sponsored Post
Steps
Step 1
Decide on the pot you want to use. Now attach the hole saw (32-38mm) to your cordless drill. Working on a stable surface, drill into the pot to create openings on each side. For a 4L square pot, make four 38mm openings on each side and openings on the bottom, and skip Step 2. For a 5L round pot, create a similar number of openings around the pot and a single opening on the bottom as shown in the next step.
As the worms decompose food scraps, all the nutrients will drain through these openings into your garden. Don’t worry about the compost worms escaping into the garden. These species are veracious eaters and will not survive long without a steady supply of food scraps. These openings will also allow garden worms to enter your farm once it becomes established.
Step 2
Using a jigsaw, cut 3–4cm from the bottom of the pot to remove the bottom. Be careful as the plastic may crack due to the vibrations from the jigsaw. If you have a pot with drainage holes at the bottom, guide the jigsaw through this opening and around the pot to remove the bottom.
Step 3
Select a spot in your garden that is easy to access or an area next to established plants. Using a shovel, dig a hole large enough for your pot. Place the worm farm into position and refill the hole with soil.
Step 4
Wearing gloves, transfer a layer of worms into the pot. To get started, use around one third of the Worms Booster pack to create a 5cm layer of worms. One box can create three worm farms in 5L pots.
Step 5
Add food scraps into the pot next and 2 litres of water to keep it moist. Don’t overfill with food scraps and leave space at least 10cm from the top.
Step 6
Cut cardboard pieces to size and immerse in water for about 15 minutes. You can also use damp newspaper. Put 2–3 layers of soaked cardboard or newspaper on top of the food scraps.
Step 7
To cover the entire farm, use a terracotta or plastic saucer, or the offcut from the bottom of your pot. Place a garden feature or potted plant on top to keep it in place. Covering the farm keeps it moist and prevents other animals from getting in.
Step 8
Add 2 litres of water every couple of days to keep the farm moist. Your worms will begin to reproduce, and you can start a farm in another area of the garden or in a raised garden bed after 2–6 months. Repeat the process of taking one third of the worms to start another farm.
