Hi there,
Im in the process of planning my next project and would be great some feedback as to how should I tackled it and what materials to use and quantities. I would like to build it just with Pine treated as it's cost effective.
I'm located in North Queensland so high winds we get,
Length: 7000 mm
Width :2700 mm (slab width)
Heigh: 2700mm (at high-test point above gutter)(plus roof)
Ideally I would just like it to be 4 posts but im not sure about the span. Also I would like it to have a minimum fall so water runs down into the yard. Basically it would be posts, 2beams, rafters running from the house down, battens, clear roofing sheets and lastly I'm considering so timber slats with spacing just to let the light through (slats would be installed as a ceiling from the inside).
Also what would be the best way to attached rafters to beam (considering the pitch, high winds and aesthetics)
Hope I don't get a mental breakdown before I knock this project off with all the planning and process involving this build lol. I'm excited
Kind regards
"Goal"
"My backyard"
