Hello,
I have a window/sliding door that goes out onto the balcony in my unit. The length is 420cm. I am looking to install a new set of curtains. The existing rod was installed by the previous owner. She has used 4x 1~m rods with 5 brackets. 2 brackets on each end, 1 in the middle and 2 half way on each side. If put my new curtains on the existing rail they wont be able to slide all the way because the existing brackets are quite thick. I am not sure C rings will go round them.
I wanted to install a new rod using these windoware rods from bunnings
https://www.bunnings.com.au/windoware-33mm-x-210cm-walnut-wooden-curtain-rod-set_p1284142
I have a few questions.
1. Does bunnings sell a rod joiner/bracket so i can join 2x 210cm rod's in the link?
2. How many brackets would i need to support the 420cm length? I was hoping to use a bracket on each end and a centre joiner for support.
Thanks!
