I have a preformed showerbase I want to fit into an old brick California bungalow bathroom. All the render/plaster has fallen away when I removed the old shower and shower base.
I am going to re-render the wall, then waterproof it with dunlop waterproofing paint and the corner tape. I have removed the old floorboards and 70s yellow tongue that was in the bathroom. I'm laying James Hardie Secura flooring panels over the old floorjoists.
My questions are around fitting and waterproofing the showerbase:
- Can I simply buildersglue the showerbase onto the new secura floorboard? (I've looked at demos online and they use screed to level the showerbase?)
- should I fit the showerbase into the wall render slightly (see diagram) so that I can waterproof the wall but then also run silicon bead between waterproofed wall and showerbase, prior to tiling?
- the showerbase has a lip, should my tile be tile-cemented to the waterproofed wall and the run free the 20 or so mm to down the lip of the showerbase, then have another bead of silicon? (see diagram)
cheers
Neal
