I have 2 hose hooks that I would like to attach to a rendered hebel wall. Can you please advise what screws I need to use and what drill bit? Also do I need to seal around the screws and if so what would you recommend I use?
Hello @Mike2021
Welcome to the Bunnings Workshop community. Thank you so much for joining us and sharing your question about how to mount hose hooks to Hebel blocks.
Before I give you any recommendations, would it be possible for you to post a photo or indicate the model number of the hook you are putting on? This will allow our members to have a better idea of what you are trying to attach to the Hebel block. Once our members see it, they can then provide you with a comprehensive recommendation on what to use.
To help you get started here is the link to Hebels Brochure for fixings: Hebels Proprietary Fixing & Brackets
Here is a handy reference to some of the common fittings used on Hebel: Fixings for use with Hebel
Please keep us updated, we look forward to seeing the photos.
Hi Eric,
It’s a Haxbury Silver Savanna Hose Hook I/N: 0077866.
Thank you.
Hi @Mike2021
Thank you so much for the quick response. I recommend using Ramset 8 x 40mm Anchor RamPlug - 20 Pack as the wall plug for your install. I suggest using an 8mm Masonry Bit as required by the Ramplugs. It's best to use Zenith 10G x 40mm Galvanised Type 17 Countersunk Head Timber Screws - 50 Pack to mount your hose hook.
You could also refer to these previous discussions about mounting to Hebel:
Please keep us updated, we look forward to seeing your hose hook mounted.
For future visitors to this question on the forum, the Hebel Technical Manual lists many methods for fixing to Hebel walls for different load types:https://hebel.com.au/wp-content/uploads/2016/11/Hebel-Tech-Man-Pt5-Fixings-Finishes-Access-2.pdf
