Guys,
I need to saw a Copper Pipe Brass Pipe Copper Tubes 4mm 5mm 300mm Long 0.45mm WallWould you have something to help?
Thanks
Hugo
Welcome to the Bunnings Workshop community @Hugo. It's wonderful to have you join us, and many thanks for your question about cutting pipes.
A pipe cutter is typically used on copper and brass tubes. It gives you a very neat cut without distorting the walls of the pipe. Something like the Haron 3 - 28mm Tube Cutter would work well, or you could use a smaller version similar to the IRWIN Mini Tube Cutter.
