Hi there. I've been lurking here for several weeks getting ideas for my deck. Just need an opinion on the plan I've come up with. I haven't draw in the joists. The deck would be 8m by 5.3m attached part way on two sides to the house. I'm thinking bearers 140mm x 45mm doubled up and spaced at 1.6m. With galv stirrups every 1.75m. The ledgers attached to the house would be same size as the bearers. Would my joists be ok at 120mm x 45mm? Or could I get away with smaller?
I only have around 180mm of height so I need to make single level structure with joist hangers. Also area is currently slabbed. Do you recommend taking them up? Or leaving them there? taking them up will get me a little more clearance underneath and perhaps be better if any moisture gets in? The entire deck is under an existing patio, however weather can still blow in. Any thoughts or advice would be appreciated. Thanks.
rough plan
messy patio area
height of deck
