Hey peeps! I have been reading and taking inspiration (thank you) for a while but first time actually posting.
I have been thinking for quite some time about building a (very) low deck for my alfresco area, roughly 7m x 4m.
I say "very" low because I must have the lowest clearance in the whole country, with only 60mm from the top of the pavers to the level of the door/house floor. Now I could take the pavers off, and that would give me an extra 6cm only, so a total of 120mm/12cm, which is still not great but I believe it'd be workable.
But since the pavers are actually super solid, perfectly levelled and flat, I have also been toying with the idea of just going over the pavers with an extremely low deck.
Has anybody ever done or heard of a decking that low? Do you think it would be a bad idea?
I was thinking I could maybe build the framing using some H3 70x35 laying them on the 70mm side so that the height would only be 35mm, using 5mm PVC board cut offs as spacers, placed at regular intervals between pavers and sleepers to allow for drainage and air flow (water would be minimal since the area is undercover). This would give me a total height of 40mm, and then just use 20mm decking boards on top to get to the total of 60mm/6cm.
Crazy? Dumb? I'd love to hear your thoughts and experience.
Thanks, regards.
