I am putting a frame up for an internal wall with a Hume sliding door cavity. The top brace will be 2400mm long. I’m using 90 x 35 timber (same as Hume door) and am asking for the best way to fix the top brace into brick. Can I drill at an angle through into brick using Dynabolts or would it be better to use a 90 degree metal plate to fix the wood to the brick with the Dynabolts?
