Getting a colour match is not possible without visiting a store. However, if you know exactly the paint colour you are after you can order via click-and-collect.
Once you press click-and-collect, please make sure to indicate which store you wish to order this from. Near the bottom of the page is an area called "Order Inquiry" you will need to fill this area with your details and the name and formula of the paint. You will also need to indicate what kind of finish you are after such as low sheen, semi-gloss, or full gloss. Low sheen is usually the default finish for walls. Once you have filled out the form just follow the prompts to finish your transaction. - EricL
