Hi Brain trust,
I’m going to be building a low deck on this concrete slab so bearers and joists same level. It measures approx. 5160 x 4260. I have approx. 150mm from concrete to top of deck to fall in line with sliding door frame
I’m thinking of using:
Galvanised brackets
90 x 45mm H3 pine so I’ve got room for adjustment and levelling
into concrete
M10/M8 75mm coach screws bracket to joists/ bearers
I will be running the decking long ways (Specrite Merbau Decking)
My challenge:
My significant other has decided she loves a outdoor concrete table 2m long x .900 wide (145kg!)
Concrete bench seat 1.6m long x .400mm wide (60kg!)
Can fit maybe 8 around the table (8 x approx. 80-90kg) although this will hardly ever happen outside of christmas time
145+60+ (8 pax x 90kg average person weight) = 925kg
My question is, is this doable with the products I’m using and also how should I strengthen the frame? Spacings? Doubling up bearers/ joists etc?
The table will be sitting in the middle of the deck so will I have only strengthen this area only?
This is a large deck and i am trying to do it the smartest way with as little punishment to my hip pocket as possible.
Any and all help much appreciated.
Thanks in advance
