Hello Im looking at repainting our garage door. What paint / what range should I use to do this? Colour is Midnight Sky. Colour bond match. Any help I would appreciate. Regards David
Welcome to the Bunnings Workshop community @David555. It's a pleasure to have you join us, and many thanks for your question on paint selection.
There is no colour called Midnight Sky in the Colorbond range, as far as I can tell. Do you have a colour called Midnight Sky, and you'd like to know the closest Colorbond colour to it?
I'd suggest using an epoxy enamel paint similar to Rust Guard by White Knight. Here's their available colour range. You could choose to use a water-based exterior paint like Dulux Weathershield, but it won't be as hard-wearing.
Sorry I meant Nightsky Black. It’s a colourbond colour. Will rust guard by white night have that colour?
As you can see the Rustguard colourbond NIGHT SKY is different in colour than the Dulux colour? It’s extremely confusing
Hi @David555,
You'll find most digital samples of colours will vary from the actual paint. Though, if that's the case here, it's an exceptionally poor representation. I've grabbed a few examples and shown them in the image below. As you can see, even Colorbond illustrates their own colour as two different variations.
Our paint suppliers, and those we don't deal with, digitally illustrate Colorbond Night Sky as a grey. I'm not sure what is going on with this, and it would take further investigation to find an answer. It's obviously not an issue with accurately displaying the black colour on-screen, as these suppliers clearly show a mid-dark grey.
I have spoken to three different Paint Experts in-store, and from their experience, when they mix Colorbond Night Sky up (in any paint), it ends up being black, not grey. Make sure you specify that it's Colorbond Night Sky, not Night Sky, as apparently there is a grey colour called that. However, I don't believe that is the discrepancy with the colours here as the suppliers have labelled this grey CB Night Sky.
We would expect that you get a colour that resembles black and not grey. I've included the Dulux colour card below, which reflects the colour you should also get in White Knight Rust Guard. Just ask the team member to check that the paint they mix is black before taking it home.
Thanks Mitchel can you just tell me when I call & order what is the exact paint description I ask for? WHITE KNIGHT RUST GUARD EXPOXY ENAMEL - NIGHTSKY COLOURBOND ?
That's the one @David555. The team member should know exactly what you're after.
Hi Mitchell,
I also want to paint my metal garage door for car access. I am just wondering whether there are any needs for preparation like removing the old paint with some chemical or sanding first?
I read your suggestions about using an epoxy enamel paint similar to Rust Guard by White Knight.
- Do I need to use any primer after sanding (if needed)?
- And do I need to mix the enamel paint with any thinner?
- And would brush painting is best for this job or would you suggest people to invest in air-spray paint gun (I think that's what they called) for this?
Any recommendations are welcomed.
Thank you in advance
Regards,
Martin
Hello @martyinbondi
Thanks for sharing your question about painting your metal garage door. It all depends on the current condition of your garage door. If there are rust spots and semi-advanced stages of rust corrosion. I suggest using White Knight 0.5L Rust Guard Rust Converter. If the paint on your garage door is flaking and peeling, it will be necessary to sand the surface to remove all the loose and flaking pieces.
It's always good practice to prime the surface of your garage door to add an extra layer of protection. There is no need to thin out the paint when applying it to your garage door. The only reason you need to thin it out is when you're using a paint spray gun. Using a spray gun does give you a professional-looking finish and you don't see any brush marks on your garage door.
However, if you've not spray painted before, it does take some practice. You'll also need to thin out the paint so that it works with the spray gun. It sounds like an interesting project, any updates you can provide would be much appreciated.
Here is a handy guide: Paint sprayer buying guide: how to choose a paint sprayer
Here is a link to a project that uses a spray gun: How to paint a fence with a spray gun
Let me tag our experienced members @Nikkaz and @KingStreetReno for their recommendations on using a paint spray gun.
Hello @EricL
Thank you again for your comments. It is very informative. My current garage door doesn't have any paint flaking/ peeling or rust spots even though we haven't done anything to it over the past 10 years+. After reading your comments, my plan will be to clean the garage door with sugar soap and then apply one layer of primer on top.
I will then learn how to use a spray gun with epoxy enamel paint suggested by @MitchellMc in his previous comments. I will check with the shop staff what ratio I need with the thinner. I am hoping @Nikkaz or @KingStreetReno can recommend a good spray gun brand and model for this job. I think it's worth the investment.
Will definitely keep you posted if any updates available. As always, thank you for all your help.
WBR,
Martin from Bondi
Hi! I am also planning to paint my garage roller door-it’s currently a cream colour but I’d like to have a wood look. Am I able to do a dark base coat then take advantage of the way the metal is imprinted to overlay a lighter brown to create the wood look? I’ve done this before but never on metal surfaces
Quite possibly, @daniT. I'd recommend doing your first coat with a 13mm nap roller to fill all the voids and the second with a 4mm nap foam roller. Do a couple of light coats with the foam roller so as not to fill the lower voids of the timber pattern. Don't lay the coat on too thickly in the first colour and coat with the 13mm nap roller, or you will fill up and diminish the texture.
