I have an existing deck supported on 90mmx90mm posts that go into stirrups in concrete. Bottom 100m of post has rotted and stirrup rusted out due to build up of mud/water. I will support deck(!) and then remove concrete pad and stirrup to replace with new. Question - can I joint a short piece (say 400mm) of new 90x90 into the bottom of existing post (which is in great condition apart from the bottom)? If so, what joint should I use? I was thinking of a lap joint + Gal plates + coach bolts?
It will be much easier than dismantling the entire deck 🙁
