I’m building a deck on my alfresco, which is extended few mitres in the lawn area too. The size of the deck is 4.5 x 4.2m. Alfresco area covers the length of 3m and remaining 1.2m is in the lawn area. It’s a low level deck as the max height I can go is around 160mm. I’m using 11x90x45mm joist across 4.5m, with side boards(90x45mm) covers all the edges of the rectangle, these are screwed together using baton screws(75mm). Joist are sitting on the pedestal( Buzon, which can bear more than 1000kg), each joist are sitting on 5 pedestals, 30cm from both side and 3 in the middle spaced evenly. 3 Pedestals are sitting on the concrete Alfresco, 2 pedestals are in lawn area and sitting on the bricks, these bricks are laid on concrete which I freshly did for this project.
I got few questions and need help from the DIY community:
1) At the moment deck is very stable. But do I need to fix few joists in alfresco area to the concrete using L brackets to avoid any movements in deck in future.
2) Do I need to put a post in the lawn area, may be 3, and fix the edge 90x45mm frame using as a bearer to give more support to the joists, these joists are already connected to it using baton screws.
3) any other suggestions
Community manager's note: Check out How to build a low-level deck for expert advice.
