Hi everyone,
I've been researching how to mount a large TV to a wall with steel frame and stumbled upon this lovely community. I've read a few discussions here, but I was unable to find a topic directly about mounting a large TV to steel framed wall.
So I've got a True Core steel framed drywall and I'm looking to mount a 75" TV, about 30kg. I've purchased this bracket here: https://www.bunnings.com.au/sanus-large-full-motion-tv-wall-mount-bracket_p0247047
The bracket itself is probably about 15kg by the feel (the weight info on the website is incorrect). So all up about 45kg to be mounted to the wall.
For the size of the bracket, I should be able to find at least 2 steel studs behind the wall, so 4 screws can be used to attach the bracket to the wall.
I'm wondering what screws I should use for the job? The supply lag screws seem unsuitable for the job (the manual says they are for timber studs). I saw this product being suggested in another topic, but wonder if they are too small for the load? (https://www.bunnings.com.au/zenith-10g-x-50mm-gold-passivated-countersunk-head-metal-screws-50-pack_p2408919)
The Zenith screws are indeed much smaller than the supplied lag screws (photo).
Toggles are also being suggested (https://www.bunnings.com.au/search/products?page=1&q=ramset%20toggle&sort=BoostOrder&pageSize=60) but they all seem to only hold 10kg each, so 40kg for 4 toggles won't be enough for the required load (maybe this means 10kg each when fixed to drywall instead of the steel stud, but I'm not sure). I also have insulation in the wall so I'm concerned that the toggles may not span out properly.
Would really appreciate any suggestions on how I should proceed. Many thanks!
