Hi Mitchell,Â
I'm about to build metal raised gardens for organic vegetables. I want to know if I can use weed mat and the best way to use it 🤔Â
Hello @hope1
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thank you for sharing your question about weed mat.
I suggest having a look at this discussion - Suggestion for lining a new garden bed by @ravstk. There was a reference to @Adam_W's guide - How to build a raised garden bed, specifically in step six on using drain fabric. Another guide worth looking at is - How to fill a raised garden bed by @Noelle.Â
However, there is no reason why you can't use a weed mat at the bottom of your raised garden bed. One of the reasons weed mat is used on timber garden beds is to prevent soil from escaping through the gaps in the timber. This will not be an issue for you as you will be using steel.
If you're thinking of using a weed mat on top of the bed to prevent weeds from growing this is also possible. As long as you've cut out a sufficient exit point for the plant, it will grow normally and will not interfere with the plant's development.
Please keep us updated with your progress, we look forward to seeing your raised garden bed ready for use.
A big thank you 😊Â
