Hello,
Does anyone know how to set up a remote sprinkler where I can control remotely when I travel around the world?
Good morning JacobZ,
Your explanation is so clear and complete. I sincerely thank you for it.
My reel hose is long enough like 10 m to cover the front 3X3 small garden I have. I can connect with the weeper hose so that it can reach 30 m. I hope it will be efficient and good enough.
I also have the back small yard located only max 10 long from the reel hose. Do you know if I can branch from 1 reel hose to 2 weeping hose?
Once again, thank you.
cheers,
Aylie
Hi @buyurownflowers,
Yes, you can do so with a Ladco Double End Coupling Hose Fitting Adapter.
Hi JacobZ,
thank you for the very valuable information. I certainly will get one from Bunnings.
you have a lovely weekend.
Do you know if Bunning can help me install garden reticulation?
thanks,
Hi Aylie (@buyurownflowers),
If you are in NSW, you could utilise our Services Marketplace. Outside of that area, you could advertise the job on Hipages or Airtasker or enlist the services of an irrigation service in your area.
