Small area in family room, has been confirmed as termites. Have been quoted high $2K, to bait. As on a pension, is this something that can be diy? Or scratch together $'s for professionals?
Hello @dip
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about eradicating termites.
I would first encourage you to get another quote for the treatment of your termite infestation.
The store does carry the Superway 500g White Ant Termite Bait and various sprays that you can use, but a pest and termite professional will have the knowledge of termite behaviour to track and handle the termites to prevent them from damaging your home further. Plus, their work will come with a warranty which is a plus for you.
If you can find a batter quote, I suggest hiring a professional so that the application of the treatment is safe and compliant.
Let me call on our experienced members @Noyade, @Dave-1 and @Nailbag for their recommendations.
Good Evening @dip
I would save your dollars and get a professional to do it. I would also follow @EricL 's suggestion and get another quote. I always try for two to three quotes so I dont get stung with a super low or over the top price.
Main reason I am suggesting to get a professional is doing it properly with confidance. There are certain things we lean and can take some errors on, getting rid of termites isnt one of the ones id take a chance on.
Definitely get a couple of more quotes @dip . A mate of mine's parents were recently quoted $6K to have a full treatment completed that didn't include the repair work for the house damage. A few quotes later they are getting the termite treatment for $2,800 with certification. The problem with termites is that if not treated properly, it can cost you dearly in the long run with more extensive damage.
Hello all,
If my tree had termites and I’ve already cut it down, but there are still termites around the roots, what should I do with the roots? Do I still need to use termite killer?
Hi @emmab1986,
If they’re left untreated, the main risk is that the colony doesn’t just stay in the roots.
Termites will keep feeding and can move through the soil to other timber sources nearby, which could include fences, landscaping timbers, or even your home if it’s within range. The roots essentially act as a food source that allows the colony to stay active in that area.
Over time, that activity can spread, making it harder to control later on.
That’s why I'd recommended you treat them with a product such as https://www.bunnings.com.au/richgro-500ml-termite-and-ant-killer-concentrate_p0046395 while you know where they are. If they are left untreated, then they can move on to an area where they will cause further damage. Please remember to take all necessary precautions including wearing a mask, gloves, long protective clothing and eye protection while using these chemicals.
In saying this, it is definitely worthwhile searching around the area to see if there is further evidence elsewhere. If they have spread, then it may be wise to contact a pest control specialist to help prevent further spread into worse areas.
