I have a store room which is partially under ground, about 1m. The external wall is single brick, I am getting water coming through the brickwork when it rains where it joins the slab and also through the wall itself.
It is impossible to get to the positive side of the water transfer due to paving and concrete stairs.
Is there a suitable product to seal the wall on the inside, I know that water usually pushes sealers away.
The part of the external wall above ground is not leaking.
