My wife has bought a full Murphy bed kit, all except for the timber bits. Attached is the overall look of the bed from their Instruction booklet.
That leaves me with 2 Questions.
1. As the Specrite panel is a laminated board, will it have sufficient strength to handle the mounts for the frame?
Hint: the usual occupants and dog will add up to about 250 - 300 kg.
My thoughts were to use the SpecRite 2200 x 600 x 26mm Multi-Use Merbau Panel as the best option to hold tight the mounting screws. The backplane and under-bed panels will probably be BC (as the facing panels need to be furniture grade) or CD 17mm ply.
2. The bed frame manufacturers suggest keeping it all together with the fittings shown in the top right of the image. In other words, the kind of light to medium-weight cupboard fixings that you could expect to find in any kitchen, or cupboard flatpack. I have successfully used these many times in the past on kitchen cupboards, shelving, and other furniture but I think the Connector Cam sets are not adequate for fixing these heavy sides to the back plate and transferring all of that strain and stress.
I have bought some packs of the Connector Cam bolts but I am open to suggestions on better ways to fix the backplane to the surrounds and butt join the two pieces of 17mm ply needed to make up the backplane and the pieces under the mattress. They suggested double-ended Cam Connectors but couldn't find any at my Parafield SA store so I also bought some of the Hafele Benchtop connectors only to find they stand too high (22mm high) and will have to go back.
What is left for me to try?
Pocket screws maybe?
