Best drill bit for vitreous china (WC)?
bazzyboy
Cultivating a Following
What's the best drill bit to drill a 5mm hole into the 15mm-thick side of a vitreous china WC (toilet tank) or toilet tank cover. Once drilled, I'll insert a flexible water tube through the hole to connect the water outlet inside the WC to the bidet using a T adapter (3-way valve.)
Re: Drill bit for vitreous china (WC)
Hi @bazzyboy
I suggest using QEP 6mm Diamond Tile Drill Bit. It includes a drill guide and a water cooling cup. It's great for cutting holes in glass, ceramic, porcelain, marble and granite. My number one tip is to never run it dry and always use the water chamber provided. The water keeps the head of the cutting bit nice and cool and prevents it from overheating.
It will take time when drilling through such a thick substance. I recommend not rushing the cutting process. Pushing too hard or running the drill bit at high speed could possibly crack the porcelain. Keep a good steady speed and let the drill bit do all the work.
Please keep us updated with your progress, we look forward to seeing your bidet ready for use.
bazzyboy
Thanks so much, Eric. I've bought this drill bit and will be tackling the job on Sunday.
Keep us updated @bazzyboy and don't hesitate to reach out if you run into any issues.
bazzyboy
Re: Best drill bit for vitreous china (WC)?
Yay, it's done! For a 6mm pipe I decided to use an 8mm drill bit, which gave a perfect fit. 6mm would have been too small.
QEP 8mm Diamond Tile Drill Bit
I/N: 6820161
It was very useful to know to take it slow and steady. I used a cordless drill - an inexpensive XU1.
The only fail was that the double-sided adhesive that came with the drill bit (to hold the guide container in place) was not adhering to the smooth porcelain and the container went spinning as soon as I started drilling and splashed water all over! Luckily, I had ordered waterproof nano tape from Amazon recently and that was put to good use for this project.
bazzyboy
Had I been even more patient, used a lower torque setting on the drill, and not applied occasional force I could have had a cleaner hole on the outside. It was very fulfilling to see the drill bit come out of the other end after more than 15 minutes of drilling.
I'm pleased to hear that your project has been successful, @bazzyboy. Please don't hesitate to reach out if you ever need assistance with a project or have something to share with the community.
Hi @bazzyboy
It's great to hear that you've managed to drill through the ceramic wall of the cistern. You made good time by drilling through in 15 minutes. It usually takes longer at slow speed. But the important thing is that you've managed to provide access to your bidet hose. Would it be possible for you to show us the three-way connection for the bidet hose? I'm sure our members who are in a similar situation would be keen to see how you attached it.
Please keep us updated with your progress, we look forward to seeing your bidet seat working.
bazzyboy
Hi Eric, please see attached images of the  3-way connection- one inlet and 2 outlets. The 3-way connector was supplied by the Sydney- based bidet distributor after I told him about the available water source and what I wanted to do. Happy to send any other information you or others may need to install a bidet.
Hi there, I'm in a similar dilemma having to drill into my cistern porcelain. I was wondering where can I get that 3 way connector and the 6mm pipe/tube ( and the fittings required for it?)
