hi I have installed an Estilo 4 lip showcase and I would like to install the Mondella semi-frameless shower enclosure. Is this possible or do I have to stick with the estillo range of frames, thanks in advance of any advice.
Hi @Newyork77,
Although the Estilo bases are designed to go with Estilo frames, they are compatible with frames that will fit on their raised lip section. If you have a 900mm Estilo base and intend on using a 900mm Mondella frame, they should be compatible with it, as far as I can tell. However, I would encourage you to speak with Plumbing Expert in-store to verify.
Thanks Mitchell
