Hello all, Have moved into a rental which has an existing wooden timber batten fixed to the wall studs in the laundry (see picture below) which the previous tenants had their dryer bracket mounted on.
How should I fix my dryer bracket to this timber batten? The instructions that came with the dryer bracket say to use coach bolts*, but how would I access the back of the timber batten to fit the bolts? Could I use coach screws instead, would they support the dryer?
(*the dryer bracket instructions say to use 6mm x 30mm coach bolts).
Thanks for any guidance!
