2 questions here
the first is that the instructions say in BOLD type
"Reinstall the locking clip. CAUTION: The Critical Line mark must always be 30mm above the overflow pipe and the inlet valve must be properly locked with the locking clip before valve is used."
Is that "at least 30mm", "exactly", or "no more than 30mm"?
The second is that there are instructions for micro level adjustment that seem to suggest there is only an adustement in the range of 0,5 to 2 mm, or am I reading it wrongly?
there are no istructions for macro adjustment.
I assume this is done by sliding open-close latch and moving the float cup up or down then turning the thumb screw to get the float back into position?
Any advice greatfully received. I have been puzzling over the instructions for days
