How to attach a Dyson vacuum bracket to Hebel wall?
thegoodlife66
Re: How to attach a dyson vacuum bracket to hebel wall
Welcome to the Bunnings Workshop community @thegoodlife66. It's brilliant to have you join us, and many thanks for your question about fixing a bracket to Hebel block.
You can treat the Hebel block like any other concrete surface. However, drill into it in non-hammer mode. You can use standard Ramplugs in the holes you've drilled and screw into them with the provided fixings.
If you can provide a picture of the bracket and any questions you have, I am sure our members will be able to suggest the best approach. Let me know if you need a hand uploading images.
Hi Mitchell.
This is a photo of the bracket
Hi Mitchell
Went back to Bunnings and the
6mm x 30mm Ramplug.
Job done !
Thanks for your advice.
Cheers
Bruno Mastrodomenico
I'm pleased to have been of assistance Bruno (@thegoodlife66). Reach out anytime you have questions about a project around the home or garden; we're here to help.
Great work.
