How to clean mould from metal door frames?
BrieD
We have a build up of black mould appearing on our aluminium door and window frames. What is the best way to remove this and prevent its regrowth?
Re: What is the best method to clean our metal door frames?
Hi @BrieD,
To clean and remove the mould, start by putting on a mask and gloves to protect yourself, then use a mould cleaner such as Selleys Rapid Mould Killer Remover and scrub it with a brush like this Oates Soft Grip Grout Brush to get into the aluminium tracks. Once the mould has been agitated, use some rags or paper towels to wipe away the liquid and mould and dispose of it.
Black mould grows when moisture is allowed to sit, so to prevent it from returning, you'll want to ensure the door and window frames are not allowed to stay wet. Check for condensation in winter and make sure windows are closed when it rains to prevent that sitting water. Keeping the air flowing around them when possible and wiping up any excess moisture will help prevent it from growing.
