Hines to connect my laundry sinks waste drain to the p trap, which is current off by 40mm.
My plan is to buy an 45degree elbow and pipes to extend so it will reach.
I want to use this product to screw directly onto the bottom of my sink and use solvent to glue a 50mm pipe to it.
https://www.bunnings.com.au/holman-50mm-dwv-pvc-female-iron-adaptor_p4750157
my question is, for the threaded connection, ie where I screw to the bottom of my sink, do I need to use some sort of sealant?? Or rubber ring or such?
i m little bit confused because looking at my existing p trap I have and the p trap kits u can buy, all the thread connections seems to have a nut and a rubber ring, but you cant seem to get those outside of a p trap kit?
