How to fix Kinetic inlet valve?
pat22
I have just installed a Kinetic inlet valve, and it is not letting water enter the cistern
please help?
Re: cister inlet valve
Hello @pat22
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your inlet valve.
There are only a number of possible points where you can investigate why the inlet valve is not working.
  • Remove the cistern hose and check that the cistern tap is working
  • Remove the cistern hose from the inlet valve and attach it to the cistern tap and test
  • Look under the cistern valve and see if it has a pressure reducing plug or debris catcher. When pushed in too far it will plug up the valve
  • Remove the cistern valve and blow into it from the bottom (air should pass through, but if not then the valve is faulty)
  • Check the float settings of the valve, it might be in the closed position.
If after doing all these trouble shooting steps and the inlet valve just won't work, I suggest bringing it back along with your docket and getting a Fluidmaster Bottom Entry Toilet Inlet Valve instead.
