<bottom> Hello,
My toilet is running. The water continues to come in after the fill line and then through the overflow into the bowl.
The float seems to correctly stop the main flow, but the hissing sound continues and the water keeps increasing.
I notice that when I apply pressure to the float/inlet tower the hissing stops and seemingly the water doesn’t keep coming so that’s my leading theory.
Another issue is the tap on the side of the toilet doesn’t seem to actually stop the water. I think the cap of the tap is just a plastic cap that is spinning but not actually turning anything. So I have to turn the water main off to the whole property to work on this. Otherwise I’d just turn this off as we don’t really use this toilet much.
Lastly, from my readings online, if I want to replace the inlet/float device I would have to disconnect it from the pipe, which is usually at the base, but as this toilet is flush against the wall I’m not sure how I can get to that connection?
Im a total noob and not against paying a plumber, just wanting to learn and increase my knowledge on it all. From what I understand the water leaves the outlet/flush tower, so I would’ve thought the leak may be there, but as I say when I put pressure on the inlet/float tower it seems to stop.
Hope I’m making some sense and thanks for any help. I’ve added a video link that showcases it.
https://streamable.com/qu81nz
