My partner and I are planning to use wet area VJ board for our bathroom/laundry reno. So far we are down to a stud wall with the walls straightened ready for sheeting.
Is any type of additional waterproofing system required where the panel meets floor tile? Also how do you finish the wall and floor tile junction? Is it just a piece of channel for the sheet to slide into or do you a small gap between the wall panel and floor tile? Or is it something else?
Hi @matteo917,
They are referring to the distance from the wall to the edge of a vessel that holds water. In your case, the basin hollow is the vessel that is holding water.
The vanity, which is the cupboard that holds the basin, can be attached to the wall as long as the basin is 75mm from the wall.
Thank you Jacob, much appreciated your help. I’ll check the vanity to make sure measurements fits requirements
