Hi everyone,
I’m looking for some advice on installing a slim curtain track. The curtain is lightweight, and combined with the track, the total weight is about 2kg. The track length is 160cm.
The installation spot is above an indoor sliding glass door frame leading outside. The left side of the spot is a cabinet, and the wall material there sounds like plaster. The track needs to be mounted flat against the top wall (not at 90 degrees).
I’m not sure what the wall material is, but when I knock on it, it sounds solid and hard, like brick or concrete.
So, I have a couple of questions:
- Is there any tool to help me identify whether the wall is brick, concrete, metal, or something else? I want to make sure it’s safe to install the curtain here.
- The curtain track comes with plugs and screws. The installation guide says to mark the holes, drill into the wall, insert the plugs, then screw in the track. What kind of drill and drill bit size should I use depending on the wall material? Should I use a hammer drill, or compact driver drill is enough?
I’m a complete beginner with tools and don’t own any electrical tools yet, so product recommendations are very welcome! Any advice or tips would be hugely appreciated.
Thanks so much in advance!😀
