We are doing a remodelling of our bathroom in Brunswick, Victoria to change the tiles on the bath, remove the current lip on the outside of the bath and also insert some false walls to cover the ledge - or in other words box the bath in.
It will be straight forward for the plumbing to come forward on the new wall at the head of the bath. This is an old timber house but renovations some 20 years ago put in concrete stumps, modern wiring and modern plumbing.
But I have seven questions before I proceed too much further.
Question 1. The bath is a steel bath and you can just see the cradle of concrete it is sitting on. The current bath 90 x 45 frame does not support the bath at all - it only provides the framework for the vertical and horizontal panels that the files were adhered to. I have removed part of the frame from the front and you can just see that the bath lip is above the supports. The only parts contacting the lip of the bath were the horizontal tiles that slid under the lip of- so they would not have taken weight other than through the silicone seal.
Is this the correct way to install this heavy bath?
Question 2. I have to put in another framework at the front so that the tiles start under the lip of the bath. I cannot do this until the issue of supporting the bath is resolved so all input gladly received.
Does the frame have to be anything else than MPG 10?
Question 3. Does it need a water proof rating? The existing timber appears to untreated MGP 10 pine.
Question 4. The false walls will enable the new tiles to sit on the lip of the bath. As they are not a load carrying wall I have been told that 70 x 45 framing will suffice. The sole plate will sit on the ledge and the top plate will sit roughly 1.5 metres above it. The wall panel will be wet area cement sheet or wet area plasterboard - yet to be decided:
Is there any reason to have heavier timber than 70 x 45?
Question 5. Does this framing need to be other than MGP 10?
Question 6. The sole plate will sit on the ledge.
However should I ensure that the weight is transferred to the floor - probably by ensuring the ledge is supported from the floor?
Question 7. Should the old tiles be removed to reduce the load on the building??
