How to join fibre cement sheeting?
Christalaura
Can I join fibre cement sheeting with fibreglass joiner tape and joint compound? Or do I need to use a thin-set cement?
I do not want to use the Dunlop cement joiner as it has terrible reviews and is very expensive.
Thank you for your time.
Re: joining fibre cement sheeting
Welcome to the Bunnings Workshop community @Christalaura. It's great to have you join us, and many thanks for your question about joining cement sheet.
Could you please tell us what type of cement sheeting it is? Is it Villaboard or Hardiflex? Villaboard is set with joint tape and James Hardie Compound Base Coat 4kg Tub. Hardieflex is typically joined with Brutus 4.5mm x 3m Building Moulding Maxi Cover.
I saw this post and I was wondering too I am patching some villaboard as bits came of from the old tiles and I didn’t want to have to replace the entire bathrooms villaboard. Would you suggest the same with joint tape and James Hardie Compound Base Coat 4kg Tub?
Hello @Bernie-Babe13
Would it be possible for you to post a photo of the damage on the villaboard? If it is very large, patching might not be possible, but small bits coming off can be patched.  Depending on the size of the bits that came off it might not be necessary to use the joint tape.
 Thanks Eric. It wasn’t tiled very well and I want to prep for wall panels
Thanks for sharing the photo (@Bernie-Babe13), that helps.
Before getting too far into repair products, it would be good to understand what your end plan is for this wall. Are you intending to patch the Villaboard and then re-tile, or are you installing wall panels over the top of this patched area?
From what can be seen, you could likely use James Hardie Compound Base Coat to fill and level the damaged areas, particularly where small sections have torn away with the old tiles. However, it’s a bit hard to tell from the photo how deep those damaged sections are. If the damage is shallow and only affects the surface layer, patching is usually fine. If the damage goes deeper into the sheet, or if large areas are weakened, the Villaboard may be structurally compromised and patching alone may not be suitable.
If you can clarify what the finished wall system will be and roughly how deep the damaged areas are, we can give more accurate advice on whether a patch repair is appropriate or if replacement of that section would be the better option.
Hi again, yes it’s very shallow 1mm and I need to finish removing all the tiles first. Then putting wet wall panels no tiles.
The best next step is to remove the rest of the tiles first and then reassess the Villaboard once everything is exposed @Bernie-Babe13. Often, once the tiles are fully off, you get a much clearer picture of how widespread the damage actually is.
A few shallow, localised chips or torn areas can certainly be patched using James Hardie Compound Base Coat and then sanded flat. That’s a perfectly acceptable approach when the sheet is largely intact. However, Villaboard is only around 6 mm thick, so if chunks have been pulled off to any significant depth across large sections of the sheet, the board can become structurally compromised.
Once you reach a point where you’re effectively patching most of the sheet rather than just small spots, it’s usually better to remove and replace that section of Villaboard altogether. Starting with a sound, flat sheet is far more reliable than trying to rebuild strength and flatness across an entire board with compound, especially behind wall panels.
Also keep in mind that depending on the type of wet wall panels you’re installing, waterproofing may still be required to meet bathroom construction requirements. If waterproofing is needed, having a fresh, undamaged sheet makes achieving a compliant and durable result much easier than working over multiple patches.
So in short, finish tile removal first, assess the extent of the damage, patch only if it’s minor and localised, and don’t hesitate to replace the sheet if the damage is more widespread.
Hi again Mitchell, yes I need to get new sheeting. Just had a question though would I need to get a professional to waterproof and do I need to get a compliance certificate. I live in the ACT. I’m so sorry for asking so many questions I was going to hire someone to remove and install new sheeting but just wanted to confirm what kind of tradesperson I should get. Thanks
Where is this area located, @Bernie-Babe13? If it's outside the shower recess and not behind the sink, then no waterproofing is required.
Whether you need a compliance certificate could be location-related. Before you go too far, it might be best to reach out to a waterproofer to get their opinion. If this is in the shower recess, you might find it difficult to get a waterproofer to sign off on a partial repair. Typically, waterproofing in a shower recess requires a single homogeneous coating, which would require removing all the tiles.
