How to prepare a bathroom for renovation?
Edgar
Cultivating a Following
Hello,
We are starting the process of renovating a small bathroom in a top floor double brick block.
After some initial disappointments, it has become clear that we need to take more control of the situation and be more focussed on managing this ourselves.
The layout of the plumbing and electrics will not change with the following exception: we are hoping to connect the waste water from the washing machine into the bath drainage.
The bathroom is on a concrete slab. We will replace the current shower over bath with a new shower over bath. Because of the odd layout, we propose adding a nib wall to facilitate installation of a shower screen (as opposed to the curtain currently used). Part of the old recessed cabinetry which currently runs into the "shower zone" will be built in and tiled.
All current fittings, wall tiles, floor tiles, toilet, basin will be replaced.
Our first question is: How far back do we need to take the strip out? It has been suggested that it need only go back to plaster, but others have suggested a full strip out to the brick may be required. Is a combination of both achievable? Or is it best to go back to a blank canvas?
Thank you
Re: Bathroom Renovation/Strip Out
Hi @Edgar,
The extent of the strip-out during your bathroom renovation can vary based on factors such as the current condition of materials, budget considerations, design changes, adherence to building codes, and personal preferences. Limiting the strip-out to the plaster might be cost-effective if the existing tiles, walls, and fixtures are in good condition. However, if there are structural issues or a desire for a complete transformation, a full strip-out to the brick may be necessary. In answer to your question, when removing your tiles there's a high likelihood that the plaster, which your tiles are adhered to, will be damaged in the process.
Check out this helpful guide: How to plan a bathroom renovation.
Edgar
Thank you so much. Apologies for the late acknowledgement of your response. Owing to the very high quotes received,( and some poor communication from tradies!) we are postponing a full renovation.  We do have many questions though which we hope to have answered. Thanks again.
Keep us updated, @Edgar, and reach out again when you have questions.
