I have a very small laundry that has a few large tiles around the sink with the remainder of the wall being normal painted gyprock. I want to remove the existing tiles (as I’ll be adding a bench over the washer/dryer) then lay fresh tiles that will cover the whole wall.
Once I remove the existing tiles, I’m expecting to have leftover plaster/grout etc. and the wall will not match the other side quality wise. Do you have any suggestions on how I should prep the part of the wall that I remove the tiles from? Sandpaper it to the gyprock where I can’t chip it off?
thanks in advance!
