On returning from holidays i found my ensuite toilet had sprung a leak somewhere behind it in the wall.
Ive had plumber remove toilet and repair said leak, but now i have questions and suggestions please.
My plan is to replace old wet underlay with cement sheet and tile over.
The vanity is sitting on existing hardwood floor boards and the old vinlyl flooring and underlay was laid up to it, im planning on keeping this the same with new flooring. The toilet was sitting on top of underlay with vinyl cut around toilet and again im planning on doing same with new. Im also planning on using vj lining as a dado height around the room to give some texture. The plasterboard is slighty damp behind toilet, should i cut this wet part out and replace with villaboard? Questions are as follows;
1. in what order should i do things?
2. villaboard down to existing floor boards, lay cement sheet up to this then waterproof then vj lining down to floor?
You can see where the current plasterboard is quite some way from floor (big gap)
Please see pics attached and thanks for any and all help! 🙂
