I am replacing the 30mm bathroom sink waste however the basin sits on a 40mm think benchtop. Hence the nut holding the waste in is well recessed 40 to 50mm in a hole in the benchtop. And the hole is not much bigger than the nut. Any idea on how to reach the nut to undo, are there long tube spanners to reach that far and that big? Or is there an extension nut that is long enough and can be screwed in?
Photo shows the silver tube goes up and there is a lock nut on the end. I may be able to just unscrew the silver tube although not sure how it is connected to the waste. And not sure it will fit the new waste. In case someone has come across it before I dismantle the waste and pipes.
