I was going to paint my laminate countertop but I’m thinking it might be a better solution to replace it. I’m happy to keep the cupboards and just replace the countertop however the counter is like a box that the cupboards sit inside. I’m struggling to find any countertops like this - is anyone able to help me with an affordable solution to upgrading this?
Hello @emmarobynx
Your benchtop has been built with a cover edge style giving the impression that you have a very thick benchtop. This type of benchtop is usually custom made and is built onsite. It is technically possible to replicate the design using Specrite 2200 x 600 x 26mm Timber Multi Use Pine Panel. A second panel must be cut to create the thick feature side of the benchtop. However, if you are after a laminated top you'll need to inform your builder so that they can cover it with a laminate sheet.
