Hi there,
We recently bought an early '90s house in Brisbane and the plastic shower drain grate is broken. It doesn't seem to be a "standard" size however, being about 11cm. The shower floor grates I've looked at on the bunnings website and elsewhere online appear to be 10cm for the actual 'grate' part and the outside fitting with the tail is approx 11cm. That would be fine, however the floor drain itself slopes inward and therefore the tail part of the fitting won't fit inside the existing drain pipe.
Is there a solution for this that doesn't involve replacing the whole thing, ie. getting a plumber out to remove the old floor drain and putting in a new one? Would like to avoid that if possible as we've had them out to do so many things recently and I'm a bit over it to be honest!! At the moment we're just keeping a silicone one on top of it so that we don't have to see it...
I've attached a couple of pictures. Apologies in advance for the grossness - hope nobody is eating!
I hope I've been clear enough about what I'm asking - I'm not great with the correct terminology for all of this stuff so please let me know if I need to explain anything more clearly!
Thanks in advance for any advice! 🙂
