My partner and I just moved into our first property and when connecting the washing machine to the tap and turning the tap on it begins to leak through the handle area. I did a bit of research and have replaced the valve and the washer but it is still continuing to leak from the same place when turned on. The leak only occurs from the handle when the washing machine is connected to the tap and the tap is turned on.
