We wanted a laundry where the washing machine was hidden behind cupboard. The space is narrow so we wanted to look bigger, we didn't need a broom cupboard, so we opted for floor and wall cupboards.
All materials used were purchased from Bunnings.
Fltatpax utility cupboards
Flatpax Modular Cabinets - Bunnings Australia
Cordless drills
spirit level
circular saw
rubber mullet
jigsaw
wall screws (ask bunning crew best screw to use depending on your wall)
pencil
screwdriver
tape measurer
villa board (to mend wall from plimber moving washing machine taps)
stands (at the time bunnings were out of stock but recommended to help support when installing wall cupboards)
Tradesman Stan The Stand Cabinet Levelling System - Bunnings Australia
laundry sink
Mondella Resonance Single Bowl Round Stainless Steel Sink - Bunnings Australia
Laundry taps
plumbing taps and bits "S bend pipes
kaboodle laminate pepper leaf benchtop
Kaboodle 2400 x 600 x 38mm Pepper Leaf Benchtop - Bunnings Australia
Plumber to move washing machine taps to fit inside cupboard
Electrician to move power point and install power point inside cupboard
Fltapax utility brochure
Bunnings Staff for tips we spoke to about 4 different ones all provided great advice and recommendations throughout the process.
How to install a two door floor cupboard DIY bunnings You Tube video
How To Assemble A Two Door Floor Cupboard - DIY At Bunnings - YouTube
How to install kitchen wall cabinets Bunnings You Tube
video
How To Install Kitchen Wall Cabinets - DIY At Bunnings - YouTube
How to install laminate benchtop DYI bunnings You tube video
How To Install Laminate Benchtop - DIY At Bunnings - YouTube
1. Measured the space and used Flatpax utility brochure to determine what cupboards sizes would fit
2 bought a new washing machine 8kg as its only 2 of us and lots of compact options out there. We made sure it would fit the space inside the cupboard.
3 we removed the old laundry trough and 2 door utility cupboard and old washing machine
4 plumber and electrician did their part and we fixed the wall after plumber was done.
5. we bought 2 x 900 floor cabinets 1x 450 floor cabinet 2 x 900 wall cabinets and 1 x 45 floor cabinet. kaboodle bench top, laundry sink, sink tap and washing machine taps
6 assembled all the cupboards together minus the doors. we made adjustments to one 900 floor cupboard
we did not install the shelved and cut the bottom shelf leaving room for cupboard feet and enough space for washing machine. Confirming there is enough space for movement of washing machine. You will see in pic the bottom panel this click to legs so we have access to clen filter or be able to take washing machine out if needed
7 placed the floor cabinets in position,used clamps and adjusted legs to make it level, checked to make sure washing machine fits then screwed the cupboard to each other and the wall checking levels at all times. we then placed the washing machine in its position inside the cupboard.
8 we then installed the benchtop cutting the whole for sink before bolting the benchtop. sink was then installed
9 we then installed the wall cabinets as you can see we improvised as we did not have stands at the time to hold the cabinets.
10 the cupboards door installation was the last step
@SJBH What a cool idea! Having the washing machine hidden away definitely makes the laundry look a lot neater 👌🏻
Thanks for sharing all the steps and for entering this awesome project into the July DIY comp!
Hi @SJBH,
We're excited to welcome you to the Bunnings Workshop community! It's wonderful that you've joined us and shared your remarkable laundry makeover. Your dedication to creating a sleek and more spacious area is truly impressive. Do you have any advice for members looking to create a laundry in their own narrow space?
Projects like yours often catch our members' attention and have the potential to be featured in our popular Top Ideas articles, including the Top 10 most popular laundry renovation projects. Perhaps your project might even make its way there someday!
We hope Workshop becomes a valuable platform for you, offering inspiration and guidance for all your DIY endeavours. If you ever need any assistance, please don't hesitate to reach out. We're here to support you throughout your DIY journey.
Katie
Good morning @SJBH
I like the straight lines of your laundry, It really "gives the room a lot of space" feeling. The above the benmch cupboards certainly give a lot as storage and I must admit as soon as I saw them I was thinking "now I could put this and that into there" ![]()
Thats a nice and clean job.
@SJBH Wow! 😍 The hidden washing machine makes all the difference. You would never even know it was a laundry room. Well done on your laundry makeover!
Hi SJBH..
Congratulations on a very nice clean installation..
When it doesn't look like a laundry..you've nailed it in my opinion..
Good luck with your entry..
Prof...
Thanks Dave-1.😁
Prof..
@SJBH This is simply lovely! Am planning on doing similar in our laundry, you have me simultaneously inspired and reassured ![]()
May I ask where you got that vase? Particularly liking that detail!
Reach out if you need any assistance with your project @demoreno. You might like to check out this guide on How to plan a laundry renovation and our Top 10 most popular laundry renovation projects for inspiration.
