I am converting half of my 9x7.5m garage into a sports room. Based on my research so far I’m going to use 70x35 framing timber for the walls at 600 centres and 175x47 ceiling joists at 600 centres also. Can I attach my ceiling sheets directly to the joists or do I need to attach battens first.
TIA
Hello @Debramac007
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your sports room project.
For your garage-to-sports-room conversion using 175x47 ceiling joists at 600mm centres, you can technically fix plasterboard ceiling sheets directly to the joists especially if you're using standard 10mm or 13mm plasterboard rated for ceiling use. However, while direct fixing is possible in some cases, there are several practical and long-term advantages to installing ceiling battens:
In summary, while you can screw plasterboard directly to ceiling joists spaced at 600mm, installing battens especially metal furring channels or timber ceiling battens at 450mm centres is a worthwhile investment for a flatter, stronger, and more durable ceiling, particularly in a living or activity space like a sports room.
