Hi team,
I’ve a carport with a roller door. I face currently the below issues with the carport which is enclosed on two sides (brick wall and roller door).
a) Rain water seems to fall into the carport from two of the open sides resulting in the peeling away of the paint from the carport floor.
b) Birds quite frequently come into the carport.
I’m looking to put some kind of a barrier to prevent the rain water falling in and to prevent entry of birds.
Can you suggest a few options to consider to put in a permanent barrier?
One option that I thought about is installing a bistro blinds as a barrier? Will this option work? OR Do I need a kind of hard structure?
Regardless of the type of barrier, a challenge i see in preventing bird entry is that an entry/exit gate is built in the vertical slat fencing (see snapshot). Whilst a barrier can be placed across most part of the open side of the carport, I think a barrier will not work right above the entry/exit gate preventing easy movement. Any thoughts or recommendation what can be done in this entry/exit area?
The measurement of the open side/gap is about 600cm by 50 cm on both
