How to paint Colorbond garage door?
Elohisa
Hi there I have a garage door I would like to repaint I think it's metal or similar? was put there in 2009. Colour is Jasper? I would like to repaint but not spray maybe with roller?? please let me know what kind of paint I need and possible price. Thanks
Re: Painting Colorbond Garage Door
Hello @Elohisa
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your Colorbond garage door.
In order to determine the condition of your garage door, would it be possible for your to post a photo of the garage door? Once we see it we can then make recommendations on how to proceed. Can you also please tell us if the surface is powdery or dusty and are there any rust holes present?
Re: How to paint Colorbond garage door?
Hi @Elohisa,
Yes, you can certainly paint your garage door and rolling it on is absolutely fine if you would prefer not to spray. As @EricL has mentioned, the first thing to look at is the condition of the existing surface, and if you are able to upload a couple of photos that would really help confirm the best approach. Let me know if you need a hand uploading images.
If there is any loose or flaking paint, that will need to be scraped off first, then lightly sanded to smooth and feather the edges so everything blends nicely. A good test is to run your hand across the door. If it leaves a chalky or powdery residue on your fingers, the surface will need a thorough clean. In that case, give the door a good scrub a couple of times using Sugar Soap and a Scotch-Brite pad, then rinse it well with clean water and allow it to dry completely.
You can topcoat with your chosen colour in an exterior paint, such as Dulux Weathershield. Spraying will give the smoothest finish, but a quality roller and brush will still produce a very good result if applied carefully.
Thank you very much. The door is still fine just a little faded with time. It's a double garage door what sort of price for paint and stuff am I looking at please?? i.e. how many litres of paint?? Can I come in for advice in-store??
Hi @Elohisa,
You would need a 4L can to cover that area with two coats, and you are certainly most welcome to attend a store and speak with one of our Paint Experts.
Hi Mitchell thank you very much for your support and advice. Much appreciated. I live in Aspley so will go down to Carseldine and see if I can get some help there.
