I'd like to modify this digital piano stand, as the pedals are too close for my long legs. 🙃
My plan is to move the panel that the pedal unit is attached to backwards by installing additional metal brackets to each side of the stand that extend behind the back of it, and then attaching the existing bracket to that somehow. The bracket holes are ~6cm apart if it matters. I'd also like to keep it looking nice with e.g. black brackets and bolts.
It would be even better if the bracket was "adjustable", so that I could make small adjustments to the panel's position to find the ideal position, but I'll settle for what I can get. This might also cause the panel to move backwards over time if not held in place securely enough...
I'm wondering if anyone has a better solution for this, or if not, suggestions for which parts I should buy.
Thanks!
